Smart Citizen Kit 2.1 3D printed frog box¶
This enclosure is to be used with the SCK 2.1. It's based on the Frog Box design, with additional modifications, remade from scratch in Blender.
- 1x cover of your choice: indoor version, freestyle version. The outdoor version is currently a WIP only, and it's meant to be used with a protective umbrella.
- 3x M3 Inserts
- 1x M3x6mm screw
- One external SC reset button
