Smart Citizen Kit 2.2 with Carbon dioxide and 2 Electrochemical Sensors¶
This enclosure is to be used with the SCK2.2. It's based on the Frog Box design, with additional modifications, remade from scratch in Blender.
- 1x cover of your choice: indoor version, freestyle version.
- 1x afe support
- 1x asb breidge
- 8x M3 Inserts
- 2x M3x20mm screws
- 6x M3x6mm screw
- One external SC reset button
