Skip to content
Smart Citizen Kit 2.2 with carbon dioxide and formaldehide sensors
RENDER
This enclosure is to be used with the SCK2.2. It's based on the Frog Box design, with additional modifications, remade from scratch in Blender.
Printing
  • No supports
  • 0.2mm layer height
  • At least 3 vertical walls
**SLICER**
Additional components
  • 9x M3 Inserts
  • 6x M3x30mm INOX screws
  • 2x M3x10mm screws
  • 1x M3x15mm screws
  • 6x M3x6mm screw
  • One external SC reset button
  • Rubber seal 2.5mm
