SCK2.2 + CO2¶
SCK2.2 with CO2 sensor.
This enclosure is to be used with the SCK2.2. It's based on the Frog Box design, with additional modifications, remade from scratch in Blender.
- 1x cover of your choice: indoor version, freestyle version. The outdoor version is currently a WIP only, and it's meant to be used with a protective umbrella.
- 6x M3 Inserts
- 4x M3x6mm screw
- One external SC reset button
