Smart Citizen Kit 2.2 with carbon dioxide and formaldehide sensors¶
This enclosure is to be used with the SCK2.2. It's based on the Frog Box design, with additional modifications, remade from scratch in Blender.
- 1x cover of your choice: indoor version, multiporpuse version.
- 1x HCHO peg
- 9x M3 Inserts
- 1x M3x15mm screws
- 6x M3x6mm screw
- One external SC reset button
