SCK 2.2 3D printed¶
This enclosure is to be used with the SCK 2.2. It's based on the Frog Box design, with additional modifications, remade from scratch in Blender.
- 1x cover of your choice: indoor version, freestyle version. The outdoor version is currently a WIP only, and it's meant to be used with a protective umbrella.
- 3x M3 Inserts
- 1x M3x6mm screw
- One external SC reset button
