SCK2.3 2EC 3D printed¶
Measure Indoor or Outdoor Air Quality with this unit. Beyond the metrics from the kit, it can measure chemical parameters alphasense A-series electrochemical sensors!
This enclosure is to be used with the SCK2.3. It's based on the Frog Box design, with additional modifications, remade from scratch in Blender.
Various cover designs
There are various covers that can be used with this enclosure:
- cover_indoor.stl is meant to be used in indoor spaces.
- cover_freestyle.stl is meant to be used with zipties, or hung on a wall but for short-term deployments.
- cover_outdoor.stl is meant to be used with an umbrella, for long-term outdoor deployments.
- 1x cover of your choice: indoor version, freestyle version or the outdoor version.
- 4x M3 Inserts
- 2x M3x6mm screws
- Umbrella (for outdoor settings)
Not outdoor by itself
For deployments outdoors, you will need to use the protective umbrella to make sure it doesn't get soaked! The umbrella can be substituted by a physical cover, for instance placing the device protected under a balcony.
