Skip to content
SCK2.3 + 2x Alphasense (A-series)
RENDER
SCK2.3 with two Alphasense sensors (A-series).
This enclosure is to be used with the SCK2.3. It's based on the Frog Box design, with additional modifications, remade from scratch in Blender.
Various cover designs
There are various covers that can be used with this enclosure: - cover_indoor.stl is meant to be used in indoor spaces. - cover_freestyle.stl is meant to be used with zipties, or hung on a wall but for short-term deployments. - cover_outdoor.stl is meant to be used with an umbrella, for long-term outdoor deployments.
Printing
  • No supports
  • 0.2mm layer height
  • At least 3 vertical walls
See the slicer capture below: **SLICER**
Additional components
  • 4x M3 Inserts
  • 6x M3x30mm INOX screws
  • 2x M3x10mm screws
  • 2x M3x6mm screws
  • Rubber seal 2.5mm
  • Umbrella (for outdoor settings)
Not outdoor by itself
For deployments outdoors, you will need to use the protective umbrella to make sure it doesn't get soaked! The umbrella can be substituted by a physical cover, for instance placing the device protected under a balcony.
