SCK2.3 (SEN5X only)¶
SCK2.3 enclosure without the Urban Board, only with a SEN5X series sensor.
This enclosure is to be used with the SCK2.3. It's made from scratch in Blender.
⚠️ WARNING: All the pieces that need to be exposed to the environment need to be printed in PETG in order to have a long live and not degrade with the direct sun or different weather conditions.
- 1x PETG outer cover
- 1x PETG mid layer
- 1x PLA shell
- 2x SCK slider CLIP
- 1x Upper base
- 1x Lower Base
- 1x battery Bridge
We have tested this on a Prusa MK3 3D printer, using PLA and PETG using the following settings:
- When printing PETG is better doing it in a closed printer to avoid warping
- 2x M3 Inserts
- 4x M4x20mm INOX screws
- Pressure relief vent link
⚠️ WARNING: For further information about this enclosure there is a post in our forum.
